[Qgis-user] Print composer from 2.10 not working in 2.12
Alexandre Neto
senhor.neto at gmail.com
Mon Apr 4 12:34:48 PDT 2016
Probably it won't help using 2.14, but can try...
In cases like that, trying not to loose all the work, I duplicate the map
composition and start eliminating items, one by one, and try to export
until I find the bad boy.
Start by the map itself as it is probably the big fish.
Also check 2.12 changelog for map composer changes, maybe you get some
hint.
Alexandre Neto
A seg, 4/04/2016, 18:37, Uwe Fischer <gisfisch at t-online.de> escreveu:
> Hello List,
> I have a QGS document with a lot of themes and a custom legend that was
> finished in QGIS 2.10. The maps had to be delivered in PDF format. Now
> there is a minor change request in one map. I have updated to 2.12 in the
> meantime. After opening the QGS, making the change, and saving it, I was
> not able to produce a proper PDF output any more. A PDF document is
> written, but is has only 2 KB and shows up empty.
> In other projects, PDF output from 2.12 works very well.
> I’d hate to reproduce the map setup and composition in 2.12 from scratch
> for that minor change. I am not sure if it makes sense to go back to 2.10
> for that?? Or is it possible that 2.14 is able to produce output from the
> older version?
> Thanks for ideas and suggestions,
> Uwe
> Ingenieurbüro Fischer
> Esbecker Str. 8
> *31036 Eime*
> Tel.: 05182/8325
> Mobil: 0172/8876934
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160404/e9d86e65/attachment.html>
