[Qgis-user] Print composer from 2.10 not working in 2.12
Springfield Harrison
stellargps at gmail.com
Mon Apr 4 12:51:37 PDT 2016
Hello all,
I have had that problem since beginning to use QGIS , 2.08 I believe, now
at 2.10.
My limited research seemed to indicate that it had to do with the
resolution and size of the PDF or jpeg, it did not seem to matter.
I think it might also relate to the amount of RAM available, but not
certain about that.
Sending the drawing directly to the plotter did not create a problem , only
writing to a file.
My resolution was to use less DPI and possibly a smaller drawing size.
Printing at larger sizes still seemed to be adequately Sharp.
Cheers . . . . . Spring Harrison
Samsung Tab 4
On Apr 4, 2016 12:35 PM, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
> Probably it won't help using 2.14, but can try...
> In cases like that, trying not to loose all the work, I duplicate the map
> composition and start eliminating items, one by one, and try to export
> until I find the bad boy.
> Start by the map itself as it is probably the big fish.
> Also check 2.12 changelog for map composer changes, maybe you get some
> hint.
> Alexandre Neto
> A seg, 4/04/2016, 18:37, Uwe Fischer <gisfisch at t-online.de> escreveu:
>> Hello List,
>> I have a QGS document with a lot of themes and a custom legend that was
>> finished in QGIS 2.10. The maps had to be delivered in PDF format. Now
>> there is a minor change request in one map. I have updated to 2.12 in the
>> meantime. After opening the QGS, making the change, and saving it, I was
>> not able to produce a proper PDF output any more. A PDF document is
>> written, but is has only 2 KB and shows up empty.
>> In other projects, PDF output from 2.12 works very well.
>> I’d hate to reproduce the map setup and composition in 2.12 from scratch
>> for that minor change. I am not sure if it makes sense to go back to 2.10
>> for that?? Or is it possible that 2.14 is able to produce output from the
>> older version?
>> Thanks for ideas and suggestions,
>> Uwe
>> Ingenieurbüro Fischer
>> Esbecker Str. 8
>> *31036 Eime*
>> Tel.: 05182/8325
>> Mobil: 0172/8876934
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160404/986f75ad/attachment.html>
