[Qgis-user] Qgis what epsg text file is using
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Apr 9 07:04:00 PDT 2016
Have you thought of just creating a custom CRS in QGIS? That could be an easy way out.
Nicolas
On Apr 9, 2016 04:07, "Andrea Peri [via OSGeo.org]" <ml-node+s1560n5260429h60 at n6.nabble.com> wrote:
For our internal use i need customize the epsg file of the PROJ.
I customize the epsg of the PROJ installed in the path /usr/loca/
But it seem dont be used from the qgis that still is doing as if the epsg was not changed.
So i guess the qgis could use an its own internal PROJ or an its internal epsg file.
If this is true, i like to know where is stored the epsg information for proj
To be able to customize also they.
Every info is welcome,
Thx
Andrea Peri
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Qgis-what-epsg-text-file-is-using-tp5260429.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-what-epsg-text-file-is-using-tp5260429p5260483.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160409/1d6885c1/attachment.html>
