[Qgis-user] Qgis what epsg text file is using
Andrea Peri
aperi2007 at gmail.com
Sat Apr 9 09:09:58 PDT 2016
Thx for info.
It is what I need to know.
A.
2016-04-09 13:26 GMT+02:00 Andre Joost <andre+joost at nurfuerspam.de>:
> Am 09.04.2016 um 10:21 schrieb Andrea Peri:
>> Hi,
>> For our internal use i need customize the epsg file of the PROJ.
>> I customize the epsg of the PROJ installed in the path /usr/loca/
>> But it seem dont be used from the qgis that still is doing as if the epsg
>> was not changed.
>> So i guess the qgis could use an its own internal PROJ or an its internal
>> epsg file.
>> If this is true, i like to know where is stored the epsg information for
>> proj
>> To be able to customize also they.
> QGIS uses its own CRS database srs.db, on Linux in
> /usr/share/qgis/resources/ and on Windows in C:\Program Files\QGIS
> Essen\apps\qgis\resources.
> During installation, it synchronizes the default file with the projections
> from an installed GDAL version. On Linux, it is crssync in /usr/lib/qgis;
> under Windows, crssync.exe is in C:\Program Files\QGIS Essen\apps\qgis.
> Once done, it does not look into the GDAL files anymore (except for external
> GDAL commands).
> You might re-run the synchronize tool, or do your changes in the srs.db,
> table tbl_srs. It is a spatialite database, so all tools that can edit
> sqlite databases should work.
> HTH,
> André Joost
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
