[Qgis-user] Preserving joined fields in Processing outputs
Havard Tveite
havard.tveite at nmbu.no
Mon Apr 11 03:47:56 PDT 2016
Since QGIS Processing Dissolve (mentioned in the issue)
accepts joined fields for the Unique ID field, the result
should contain that field.
So it seems most logical to include joined fields in the
result.
HÃ¥vard
On 11. april 2016 11:46, Alexander Bruy wrote:
> Hi all,
> and sorry for cross-posting.
> When cleaning Processing bug queue I found issue [0] about preserving
> joined fields in Procesing outputs. Before implementing this I want to hear
> opinions, does it makes sense at all or better to leave things as is: output
> layer contains only provider (non-joined, not virtual) fields from input layer?
> Thanks
> [0] https://hub.qgis.org/issues/12893
