[Qgis-user] QGIS-PLUGIN--GRASS
Radim Blazek radim.blazek at gmail.com
Mon Apr 11 04:32:22 PDT 2016
On Thu, Apr 7, 2016 at 2:51 PM, Paul Shapley <p.shapley at gmail.com> wrote:
> Hi,
> I'm trying to get the 'libgrassplugin7.so' library working with QGIS 2.14.1-
> 'Essen' on Ubuntu 15.10. I get the following error:-
> "Plugin libgrassplugin7: The plugin will be disabled because it crashed QGIS
> during last startup. Please report an issue and re-enable the plugin when
> the problem has been solved" in the yellow panel.
Can you remove /Plugins/watchDog/<plugin name> from QGIS settings
($HOME/.config/QGIS/QGIS2.conf) and try to find out (log) why it is
crashing.
Is there a UI to remove plugin from watchDog?
I don't think that cc650f93 reenableas plugin once it got to watchDog,
because if it is in watchDog, it is set to false in /Plugins/<plugin
name> and thus not tried to load.
Radim
> There is no error reported in the 'plugin' log
> installation details:-
> Package from: http://qgis.org/debian wily main
> Plugin: qgis-plugin-grass 1:2.14.1+23wily (latest version)
> Grass v7.0.3 r00000
> I am wondering whether it requires a different release of GRASS installed to
> work.
> Any ideas welcome
> Many Thanks,
> Paul Shapley
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
