[Qgis-user] Problem with QGIS 2.14.1 and MapInfo 12.0.3 coexistence and sharing the same data
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Tue Apr 12 04:12:03 PDT 2016
Claus -
(Not tested, just a suggestion) Try to make all the files used for a
MapInfo layer (.tab, .id, .dat. map..) read-only for the QGIS users.
QGIS 2.14 is using a new version of GDAL/OGR (2.0) to read and write tab
files. This new version of GDAL/OGR is is probably locking the MapInfo
files with a file lock because it prepares the files for update
operations. Updates was not possible for earlier versions of GDAL/OGR.
If you set the read-only attribute on the MapInfo files, QGIS (aka the
GDAL/OGR subsystem) might not generate the file lock that makes it
impossible for MapInfo to read the files.
Regards
Bo Victor Thomsen
Municipality of Frederikssund, Denmark
Den 12-04-2016 kl. 12:57 skrev Claus Sørensen:
> with QGIS and MapInfo coexistence.
> I have no problems opening the same MapInfo tab file (native mapinfo
> 7.8 format) from 2 pc's ru
