[Qgis-user] Problem with QGIS 2.14.1 and MapInfo 12.0.3 coexistence and sharing the same data
Mats Elfström
mats.elfstrom at gmail.com
Tue Apr 12 04:43:43 PDT 2016
Hi!
Most likely, this will baffle MapInfo and result in unpredictable behaviour.
Also, the ticket referred to claims that QGIS ignores read-only locks on files.
Which in itself is a rather surprising bit of information if true.
Hälsning / Regards
Mats.E
Skickat från min / Sent from my iPad, Ursäkta att jag är kortfattad / Excuse my brevity.
> 12 apr. 2016 kl. 13:12 skrev Bo Victor Thomsen <bo.victor.thomsen at gmail.com>:
> Claus -
> (Not tested, just a suggestion) Try to make all the files used for a MapInfo layer (.tab, .id, .dat. map..) read-only for the QGIS users.
> QGIS 2.14 is using a new version of GDAL/OGR (2.0) to read and write tab files. This new version of GDAL/OGR is is probably locking the MapInfo files with a file lock because it prepares the files for update operations. Updates was not possible for earlier versions of GDAL/OGR.
> If you set the read-only attribute on the MapInfo files, QGIS (aka the GDAL/OGR subsystem) might not generate the file lock that makes it impossible for MapInfo to read the files.
> Regards
> Bo Victor Thomsen
> Municipality of Frederikssund, Denmark
>> Den 12-04-2016 kl. 12:57 skrev Claus Sørensen:
>> with QGIS and MapInfo coexistence.
>> I have no problems opening the same MapInfo tab file (native mapinfo 7.8 format) from 2 pc's ru
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
