[Qgis-user] QGIS-PLUGIN--GRASS
Radim Blazek
radim.blazek at gmail.com
Thu Apr 14 23:24:07 PDT 2016
The message "The plugin will be disabled because it crashed QGIS
during last startup...." should only appear if there
"/Plugins/watchDog/libgrassplugin7" in QGIS2.conf, which is add if the
plugin crasshed QGIS last time. I have doubts that QGIS can recover
itself, as I wrote in previous mails.
The watchDog was introduced by Matthias in fa40e78f and fixed(?) in
cc650f93. Mathias, can you comment?
Radim
On Thu, Apr 14, 2016 at 11:03 PM, Paul Shapley <p.shapley at gmail.com> wrote:
> Hi Radim,
> I've attached the QGIS output from the shell (on startup) but i didn't find
> any reference to what you mentioned in the QGIS2.conf file only the
> following references:-
> [Plugins]
> libgrassplugin7=true
> [GRASS]
> windows\tools\geometry=@ByteArray(\x1\xd9\xd0\xcb\0\x1\0\0\0\0\x2s\0\0\0x\0\0\x4\xa7\0\0\x2\x96\0\0\x2s\0\0\0x\0\0\x4\xa7\0\0\x2\x96\0\0\0\0\0\0)
> Thanks.
> Paul
> On 14 April 2016 at 13:43, Radim Blazek <radim.blazek at gmail.com> wrote:
>> On Wed, Apr 13, 2016 at 1:28 PM, Paul Shapley <p.shapley at gmail.com> wrote:
>> > Hi Radim,
>> > Thanks for your kind reply...unfortunately i tried your suggestion (as i
>> > understood it) but no change. I then changed to the QGIS nightlies with
>> > GRASS 7.0.3 stable and now i get the following error:-
>> > GRASS init error: Problem in GRASS initialization, GRASS provider and
>> > plugin
>> > will not work : Module built against version $Revision: 64733 $ but
>> > trying
>> > to use version $Revision: 67364 $. You need to rebuild GRASS GIS or
>> > untangle
>> > multiple installations.
>> > so i seems if i use QGIS stable and Grass 7.0.3 i get the error:
>> > Plugin libgrassplugin7: The plugin will be disabled because it crashed
>> > QGIS
>> >> during last startup. Please report an issue and re-enable the plugin
>> >> when
>> >> the problem has been solved" in the yellow panel.
>> If you remove /Plugins/watchDog/libgrassplugin7 from config, qgis
>> crashes on start?
>> Does it print something when started from shell? Can you post backtrace?
>> Radim
>> > My only option appears to be to install GRASS r64733? Would anyone
>> > agree?
>> > Many thanks for your time.
>> > Paul Shapley
>> > On 11 April 2016 at 12:32, Radim Blazek <radim.blazek at gmail.com> wrote:
>> >> On Thu, Apr 7, 2016 at 2:51 PM, Paul Shapley <p.shapley at gmail.com>
>> >> wrote:
>> >> > Hi,
>> >> > I'm trying to get the 'libgrassplugin7.so' library working with QGIS
>> >> > 2.14.1-
>> >> > 'Essen' on Ubuntu 15.10. I get the following error:-
>> >> > "Plugin libgrassplugin7: The plugin will be disabled because it
>> >> > crashed
>> >> > QGIS
>> >> > when
>> >> Can you remove /Plugins/watchDog/<plugin name> from QGIS settings
>> >> ($HOME/.config/QGIS/QGIS2.conf) and try to find out (log) why it is
>> >> crashing.
>> >> Is there a UI to remove plugin from watchDog?
>> >> I don't think that cc650f93 reenableas plugin once it got to watchDog,
>> >> because if it is in watchDog, it is set to false in /Plugins/<plugin
>> >> name> and thus not tried to load.
>> >> Radim
>> >> > There is no error reported in the 'plugin' log
>> >> > installation details:-
>> >> > Package from: http://qgis.org/debian wily main
>> >> > Plugin: qgis-plugin-grass 1:2.14.1+23wily (latest version)
>> >> > Grass v7.0.3 r00000
>> >> > I am wondering whether it requires a different release of GRASS
>> >> > installed to
>> >> > work.
>> >> > Any ideas welcome
>> >> > Many Thanks,
>> >> > Paul Shapley
>> >> > _______________________________________________
>> >> > Qgis-user mailing list
>> >> > Qgis-user at lists.osgeo.org
>> >> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Paul J. Shapley MSc CGeog (GIS) FRGS
