[Qgis-user] QGIS-PLUGIN--GRASS
    Radim Blazek
    radim.blazek at gmail.com
    Thu Apr 14 05:43:19 PDT 2016
On Wed, Apr 13, 2016 at 1:28 PM, Paul Shapley <p.shapley at gmail.com> wrote:
> Hi Radim,
> Thanks for your kind reply...unfortunately i tried your suggestion (as i
> understood it) but no change. I then changed to the QGIS nightlies with
> GRASS 7.0.3 stable and now i get the following error:-
> GRASS init error: Problem in GRASS initialization, GRASS provider and plugin
> will not work : Module built against version $Revision: 64733 $ but trying
> to use version $Revision: 67364 $. You need to rebuild GRASS GIS or untangle
> multiple installations.
> so i seems if i use QGIS stable and Grass 7.0.3 i get the error:
> Plugin libgrassplugin7: The plugin will be disabled because it crashed QGIS
>> during last startup. Please report an issue and re-enable the plugin when
>> the problem has been solved" in the yellow panel.
If you remove  /Plugins/watchDog/libgrassplugin7 from config, qgis
crashes on start?
Does it print something when started from shell? Can you post backtrace?
Radim
> My only option appears to be to install GRASS r64733? Would anyone agree?
> Many thanks for your time.
> Paul Shapley
> On 11 April 2016 at 12:32, Radim Blazek <radim.blazek at gmail.com> wrote:
>> On Thu, Apr 7, 2016 at 2:51 PM, Paul Shapley <p.shapley at gmail.com> wrote:
>> > Hi,
>> > I'm trying to get the 'libgrassplugin7.so' library working with QGIS
>> > 2.14.1-
>> > 'Essen' on Ubuntu 15.10. I get the following error:-
>> > "Plugin libgrassplugin7: The plugin will be disabled because it crashed
>> > QGIS
>> > when
>> Can you remove /Plugins/watchDog/<plugin name> from QGIS settings
>> ($HOME/.config/QGIS/QGIS2.conf) and try to find out (log) why it is
>> crashing.
>> Is there a UI to remove plugin from watchDog?
>> I don't think that cc650f93 reenableas plugin once it got to watchDog,
>> because if it is in watchDog, it is set to false in /Plugins/<plugin
>> name> and thus not tried to load.
>> Radim
>> > There is no error reported in the 'plugin' log
>> > installation details:-
>> > Package from: http://qgis.org/debian wily main
>> > Plugin: qgis-plugin-grass 1:2.14.1+23wily (latest version)
>> > Grass v7.0.3 r00000
>> > I am wondering whether it requires a different release of GRASS
>> > installed to
>> > work.
>> > Any ideas welcome
>> > Many Thanks,
>> > Paul Shapley
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Paul J. Shapley MSc CGeog (GIS) FRGS
