[Qgis-user] Trigger actions of CADDigitize plugin from pyqgis
    lb
    coder at tuxfamily.org
    Fri Apr 15 00:11:18 PDT 2016
Hi Marian,
Just wait some days, I will release the next version (0.2.0) of
CADDigitize. I partially rewrite it from scratch.
You can see the repo here: https://gitlab.com/lbartoletti/CADDigitize/
Regards.
On 14.04.2016 15:26, Tudorache, Marian wrote:
> Hi everyone,
> I have a question about how to use CADDigitize plugin from pyqgis.
> 1.I would like to get the active instance of this plugin from
> QgisInterface (iface). I understand when the plugin is installed there
> is a reference of this plugin recorded here (iface).
> Is it possible to do this?
> Thanks,
> Marian
> *From:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf Of *lb
> *Sent:* September-20-15 2:25 AM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] About QgsGeometry::buffer
> Hi,
> Buffer require some parameter since you can choose the "style" of
> buffer. You have some example on PostGis documentation (parameters are
> the same)
> http://postgis.net/docs/ST_Buffer.html
> QGis define this parameters in Settings->Options->Digitizing->Curve
> offset tool.
> You can get this parameters via QSettings :
> join = QSettings().value("Qgis/digitizing/offset_join_style", 0, type=int)
> quad = QSettings().value("Qgis/digitizing/offset_quad_seg", 8, type=int)
> endCap = quad
> miter = QSettings().value("Qgis/digitizing/offset_miter_limit", 5,
> type=int)
> Regards
> l.bartoletti
> Le 18/09/2015 23:12, Tudorache, Marian a écrit :
>     Hi everyone,
>     I would like to find more details about QgsGeometry::buffer with
>     more styles.
>     In QGIS API Documentation there are two version of the buffer:
>     Simple version with distance and segments and with sytles.
>     The one with styles is defines as: ( distance, segments,
>     endCapStyle, joinStyle, mitreLimit );
>     I do not understand the followings parameters:
>     endCapStyle: Round (1) / Flat (2) / Square (3) end cap style
>     joinStyle: Round (1) / Mitre (2) / Bevel (3) join style
>     mitreLimit: Limit on the mitre ratio used for very sharp corners
>     Does someone has some examples or recommend a book where to find
>     more details please?
>     The QGIS API Documentation does not give me too much.
>     Thanks,
>     Marian
>     This electronic message, as well as any transmitted files included
>     in the electronic message, may contain privileged or confidential
>     information and is intended solely for the use of the
>     individual(s) or entity to which it is addressed. If you have
>     received this electronic message in error please notify the sender
>     immediately and delete the electronic message. Any unauthorized
>     copying, disclosure or distribution of the electronic message is
>     strictly forbidden. NAV CANADA accepts no liability for any damage
>     caused by any virus and/or other malicious code transmitted by
>     this electronic communication.
>     Le présent message électronique et tout fichier qui peut y être
>     joint peuvent contenir des renseignements privilégiés ou
>     confidentiels destinés à l’usage exclusif des personnes ou des
>     organismes à qui ils s’adressent. Si vous avez reçu ce message
>     électronique par erreur, veuillez en informer l’expéditeur
>     immédiatement et supprimez le. Toute reproduction, divulgation ou
>     distribution du présent message électronique est strictement
>     interdite. NAV CANADA n’assume aucune responsabilité en cas de
>     dommage causé par tout virus ou autre programme malveillant
>     transmis par ce message électronique.
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160415/a6610fb1/attachment.html>
