[Qgis-user] Trigger actions of CADDigitize plugin from pyqgis
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Thu Apr 14 06:26:07 PDT 2016
Hi everyone,
I have a question about how to use CADDigitize plugin from pyqgis.
1. I would like to get the active instance of this plugin from QgisInterface (iface). I understand when the plugin is installed there is a reference of this plugin recorded here (iface).
Is it possible to do this?
Thanks,
Marian
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of lb
Sent: September-20-15 2:25 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] About QgsGeometry::buffer
Buffer require some parameter since you can choose the "style" of buffer. You have some example on PostGis documentation (parameters are the same)
http://postgis.net/docs/ST_Buffer.html
QGis define this parameters in Settings->Options->Digitizing->Curve offset tool.
You can get this parameters via QSettings :
join = QSettings().value("Qgis/digitizing/offset_join_style", 0, type=int)
quad = QSettings().value("Qgis/digitizing/offset_quad_seg", 8, type=int)
endCap = quad
miter = QSettings().value("Qgis/digitizing/offset_miter_limit", 5, type=int)
Regards
l.bartoletti
Le 18/09/2015 23:12, Tudorache, Marian a écrit :
Hi everyone,
I would like to find more details about QgsGeometry::buffer with more styles.
In QGIS API Documentation there are two version of the buffer:
Simple version with distance and segments and with sytles.
The one with styles is defines as: ( distance, segments, endCapStyle, joinStyle, mitreLimit );
I do not understand the followings parameters:
endCapStyle: Round (1) / Flat (2) / Square (3) end cap style
joinStyle: Round (1) / Mitre (2) / Bevel (3) join style
mitreLimit: Limit on the mitre ratio used for very sharp corners
Does someone has some examples or recommend a book where to find more details please?
The QGIS API Documentation does not give me too much.
Thanks,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l'usage exclusif des personnes ou des organismes à qui ils s'adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l'expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n'assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160414/61bd441c/attachment.html>
