[Qgis-user] QGIS Security warning: project macros have been	disabled.
    Tudorache, Marian
    Marian.Tudorache at navcanada.ca
    Fri Apr 15 13:31:26 PDT 2016
I have tried to launch a python script when QGIS project is open.
Inside Project Properties/Macros I have included in th macros area
iface to access QGIS API interface or Type help(iface) for more info
def openProject():
    execfile(u'/opt/support_sw/current/spam/python/Controllers/spam_menu.py'.encode('UTF-8'))
def saveProject():
    pass
def closeProject():
    pass
The script does not start and I get this warning message: QGIS Security warning: project macros have been disabled.
This used to work on QGIS 2.8.
Is anything new in QGIS 2.10 which affects the macros launching?
Thanks,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
