[Qgis-user] crash when loading svg marker
Joris Hintjens jorishin at gmail.com
Fri Apr 22 11:27:01 PDT 2016
Dear NYell,
Thanks for your remark,
It’s the standard QGIS svg file directory , changed nothing to these settings, and I did not recently change any svg within that directory.
Joris
> Op 22 apr. 2016, om 14:05 heeft Nyall Dawson <nyall.dawson at gmail.com> het volgende geschreven:
> It's likely there's a bad SVG somewhere in your svg search paths which is causing this crash.
> If you can track down which one it is and share it then I should be able to avoid the crash.
> Nyall
> On 22 Apr 2016 21:44, "Joris Hintjens" <jorishin at gmail.com <mailto:jorishin at gmail.com>> wrote:
> > Hello,
> > Just upgraded to 2.14 on OSX Capitan.
> > Fooling around a bit, made a project (accessible on
> > https://dl <https://dl/> dropboxusercontent com/u/23700421/test zip
> > (replace spaces with dots)
> > When I try to change the style of one of the point layers to a SVG, QGIS cra&shes.
> > (Layer properties>style>marker> change drop down from “stanard” to “svg” and BOOM.
> > worked fine on 2.12
> > any ideas where to look to solve this problem?
> > thanks
> > Joris
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160422/74f8af65/attachment.html>
