[Qgis-user] crash when loading svg marker
Richard Duivenvoorde rdmailings at duif.net
Sat Apr 23 08:03:25 PDT 2016
Hi Joris,
NOT confirmed here (but on Debian, don't own a Mac), I opened your
project and changed all point layers to svg symbols without a problem...
Are you sure Settings/Options/System/SVG-Path is empty? And not pointing
to some strange dir or so?
Did you already try to open this project on another (mac) system?
And what about opening QGIS from the command line with
  qgis --configpath /tmp
so you will have no active plugins and start with a fresh configuration?
Does that help, maybe?
Regards,
On 22-04-16 20:27, Joris Hintjens wrote:
> Dear NYell,
> Thanks for your remark,
> It’s the standard QGIS svg file directory , changed nothing to these
> settings, and I did not recently change any svg within that directory.
> Joris
>> Op 22 apr. 2016, om 14:05 heeft Nyall Dawson <nyall.dawson at gmail.com
>> <mailto:nyall.dawson at gmail.com>> het volgende geschreven:
>> It's likely there's a bad SVG somewhere in your svg search paths which
>> is causing this crash.
>> If you can track down which one it is and share it then I should be
>> able to avoid the crash.
>> Nyall
>> On 22 Apr 2016 21:44, "Joris Hintjens" <jorishin at gmail.com
>> <mailto:jorishin at gmail.com>> wrote:
>> > Hello,
>> > Just upgraded to 2.14 on OSX Capitan.
>> > Fooling around a bit, made a project (accessible on
>> > https://dl <https://dl/> dropboxusercontent com/u/23700421/test zip
>> > (replace spaces with dots)
>> > When I try to change the style of one of the point layers to a SVG,
>> QGIS cra&shes.
>> > (Layer properties>style>marker> change drop down from “stanard” to
>> “svg” and BOOM.
>> > worked fine on 2.12
>> > any ideas where to look to solve this problem?
>> > thanks
>> > Joris
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
