[Qgis-user] Edit in coordinates for points manually
ralfwessels
gis at ralf-wessels.de
Mon Dec 5 08:48:32 PST 2016
Hi Lene,
there is a panel called "Vertex Editor" which is available when you start
the Node Tool to edit vertices in point, lines and polygons.
Here you can edit by writing the x,y coordinates.
I don't know if it should show up automatically, but if not you have to
activate this panel under View > Panels. You can only activate it, when the
Node Tool is selected before.
This is for editing. If you like to digitize points by writing the
coordinates I can recommend the "NumericalDigitize"-plugin.
Ralf
View this message in context: http://osgeo-org.1560.x6.nabble.com/Edit-in-coordinates-for-points-manually-tp5298643p5298658.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
