[Qgis-user] Edit in coordinates for points manually
Lene Fischer lfi at ign.ku.dk
Wed Dec 7 21:36:25 PST 2016
Hi Saber,
Thanks for the suggestion - I have installed the plugin and tried to follow the instructions - but it does not work...
I´ll try it out tonight when I have more time.
Regards
Lene Fischer
Lektor
Københavns Universitet
Det Natur- og Biovidenskabelige Fakultet
Nødebovej 77a
3480 Fredensborg
DIR 40115084
MOB 40115084
lfi at ign.ku.dk
-----Oprindelig meddelelse-----
Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Saber Razmjooei
Sendt: 5. december 2016 17:05
Til: 'QGIS User List' <Qgis-user at lists.osgeo.org>
Emne: Re: [Qgis-user] Edit in coordinates for points manually
Hi Lene,
You can use the new Node tool prototype (works fine as a plugin) + the Advanced Digitizing tools:
https://github.com/wonder-sk/CadNodeTool
See animation in the point 7:
https://github.com/qgis/QGIS-Enhancement-Proposals/issues/69
Hopefully the new node tool will be in QGIS 3
Cheers
Saber
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Lene Fischer
Sent: 05 December 2016 13:21
To: 'QGIS User List'
Subject: [Qgis-user] Edit in coordinates for points manually
I have a lot of points which have to be edited in position.
Is there a way to manually edit a points x and y coordinate by writing ?
The idea of writing in the attribute table > exporting as CSV > importing as text is not a solution :-)
Regards
Lene Fischer
Associate Professor
University of Copenhagen
Department of Geoscience and Natural Resource Management Forest and Landscape College Nødebovej 77a
3480 Fredensborg
Denmark
DIR +45 35331579
MOB +45 40115084
lfi at ign.ku.dk
www.ign.ku.dk
Qgis-user mailing list
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
