[Qgis-user] New user problems
G A Sansom
gasansom at npoint.net
Wed Dec 7 15:56:31 PST 2016
OK. I am new to QGIS, but not so new to GIS in general.
Using 2.14.7 Essen and working through the QGIS-2.14-UserGuide-en.pdf
and a tutorial that I found on the web (Treglia_QGIS_Tutorial_2_12.pdf)
I have 3 problems (so far!)
1)When setting Relations (in the Project Properties) and creating a new
Relation with a name but nothing else, QGIS throws a dump (30+ meg)
and sometimes simply quits at that time.
Getting past this, so far I haven’t been able to see anything useful with
this feature.
2)Occasionally, when attempting to set symbology properties for a
Polygon shape file, QGIS starts treating the shape file like a LINE shape.
Even though it is a Polygon, only allowing line type symbology. It also
does NOT display anything of the data while doing this.
I am certain that it is a Polygon;for a while it did display the layer and
allowed me to set a fill color.
Additionally, it allowed me to make a data column and fill it with $area,
which I assume that it would not allow if it was an unclosed line.
The only work-around that I can find is to remove the offending layer
and to bring it back into the project. If you have already placed in into
the Print Composer, this is more than a little inconvenient.
3)Using the Print Composer, I built a map, then built an inset map to
show the big picture.When I attempted to export the composition, as
image, pdf or jpg it seems to refresh all of the maps on the page.This
makes it impossible to create the composition a single page production
map.
I have not found any work-around for this.
This last item, with no work-around, is a show stopper.
Alan
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161207/dfc1d5b3/attachment.html>
