[Qgis-user] New user problems
    DelazJ
    delazj at gmail.com
    Wed Dec  7 16:31:51 PST 2016
welcome to QGIS! Comments inline.
2016-12-08 0:56 GMT+01:00 G A Sansom <gasansom at npoint.net>:
> OK. I am new to QGIS, but not so new to GIS in general.
> Using 2.14.7 Essen and working through the QGIS-2.14-UserGuide-en.pdf
> and a tutorial that I found on the web (Treglia_QGIS_Tutorial_2_12.pdf)
> I have 3 problems (so far!)
> 1)  When setting Relations (in the Project Properties) and creating a new
> Relation with a name but nothing else, QGIS throws a dump (30+ meg)
> and sometimes simply quits at that time.
> Getting past this, so far I haven’t been able to see anything useful with
> this feature.
Maybe should you read
http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/attribute_table.html#creating-one-to-many-relations
to see what the relations are designed for.
> 2)  Occasionally, when attempting to set symbology properties for a
> Polygon shape file, QGIS starts treating the shape file like a LINE shape.
> Even though it is a Polygon, only allowing line type symbology.  It also
> does NOT display anything of the data while doing this.
> I am certain that it is a Polygon;  for a while it did display the layer
> and
> allowed me to set a fill color.
> Additionally, it allowed me to make a data column and fill it with $area,
> which I assume that it would not allow if it was an unclosed line.
> The only work-around that I can find is to remove the offending layer
> and to bring it back into the project.  If you have already placed in into
> the Print Composer, this is more than a little inconvenient.
Weird! No idea
> 3)  Using the Print Composer, I built a map, then built an inset map to
> show the big picture.  When I attempted to export the composition, as
> image, pdf or jpg it seems to refresh all of the maps on the page.  This
> makes it impossible to create the composition a single page production
> map.
> I have not found any work-around for this.
You can fix the content of each map item by checking "Lock layers for map
items" in its properties tab or creating a layer preset.
See
http://docs.qgis.org/2.14/en/docs/user_manual/print_composer/composer_items/composer_map.html#main-properties
HTH,
Harrissou
> This last item, with no work-around, is a show stopper.
> Alan
> [image: Avast logo]
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
> This email has been checked for viruses by Avast antivirus software.
> www.avast.com
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161208/4489159f/attachment.html>
