[Qgis-user] Grass Processing module r.resamp.rst only accepts integer resolution
Victor Olaya
volayaf at gmail.com
Thu Dec 8 23:56:58 PST 2016
Bob
Looks like the parameter is wrongly declared to be an integer. I just
fixed it in the current development branch. I will now backport the
change to the 2.18 and 2.14 branches, so the fix is available in the
next releases
Thanks for reporting this bug
2016-12-08 20:06 GMT+01:00 Bob and Deb <bobdebm at gmail.com>:
> Hello All,
> I just noticed that the Grass Processing module r.resamp.rst only accepts
> integer resolution (ew_res, ns_res). According to the GRASS docs, those
> parameters are supposedly of type float:
>> r.resamp.rst [-td] input=name ew_res=float ns_res=float [elevation=name]
>> [slope=name] [aspect=name] [pcurvature=name] [tcurvature=name]
>> [mcurvature=name] [smooth=name] [maskmap=name] [overlap=integer]
>> [zscale=float] [tension=float] [theta=float] [scalex=float] [--overwrite]
>> [--help] [--verbose] [--quiet] [--ui]
> This is happening with OSGeo4W 64 bit QGIS 2.18 . Greatly appreciate any
> assistance!
> Bob
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
