[Qgis-user] [Qgis-use4r] Grass Processing module r.resamp.rst only accepts integer resolution
Bob and Deb
bobdebm at gmail.com
Fri Dec 9 18:49:06 PST 2016
I was able to use r.resamp.rst...thanks!
On Dec 8, 2016 11:56 PM, "Victor Olaya" <volayaf at gmail.com> wrote:
> Bob
> Looks like the parameter is wrongly declared to be an integer. I just
> fixed it in the current development branch. I will now backport the
> change to the 2.18 and 2.14 branches, so the fix is available in the
> next releases
> Thanks for reporting this bug
> 2016-12-08 20:06 GMT+01:00 Bob and Deb <bobdebm at gmail.com>:
> > Hello All,
> > I just noticed that the Grass Processing module r.resamp.rst only accepts
> > integer resolution (ew_res, ns_res). According to the GRASS docs, those
> > parameters are supposedly of type float:
> >> r.resamp.rst [-td] input=name ew_res=float ns_res=float [elevation=name]
> >> [slope=name] [aspect=name] [pcurvature=name] [tcurvature=name]
> >> [mcurvature=name] [smooth=name] [maskmap=name] [overlap=integer]
> >> [zscale=float] [tension=float] [theta=float] [scalex=float]
> [--overwrite]
> >> [--help] [--verbose] [--quiet] [--ui]
> > This is happening with OSGeo4W 64 bit QGIS 2.18 . Greatly appreciate any
> > assistance!
> > Bob
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161209/f54e5faa/attachment.html>
