[Qgis-user] Lat/Long Grids
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sun Dec 11 07:46:11 PST 2016
You also find the equivalent in dd and use that.
This should help
http://www.equationsheets.com/latlon.xls
If it's just for printing, Lene has a better solution.
Nicolas
> Le 11 déc. 2016 à 03:45, Lene Fischer [via OSGeo.org] <ml-node+s1560n5299485h96 at n6.nabble.com> a écrit :
> Hi Grant,
> In the Print Composer>Item Properties>Map you can find Grids / Draw Grid/ Draw Coordinate
> Here you can specify the CRS and the format of the coordinates.
> Here a quick video for an example (Sorry forgot to turn on the mic): http://www.screencast.com/t/yy83fxLPm
> Regards
> Lene Fischer
> From: Qgis-user [[hidden email]] on behalf of Grant Boxer [[hidden email]]
> Sent: 11 December 2016 07:05
> To: [hidden email]
> Subject: [Qgis-user] Lat/Long Grids
> Is there a way to draw a geographic grid with degrees-min with exact minutes? I don’t seem to be able to find the option to specify the degrees-minutes option when displaying coordinates in the map composer. I get decimal degrees-minutes with odd decimal grid values (e.g. 16deg 42.7’ for example). The interval is only displayed in decimal degrees. Is there an option to specify the minute value?
> Grant Boxer
> Consultant Geologist (FAIG R.P. Geo)
> Perth, Western Australia
> Email: [hidden email]
> Mobile: 0418 954 059
> Skype: grantboxer
> Website: www.iinet.net.au/~gboxer
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Lat-Long-Grids-tp5299482p5299485.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Lat-Long-Grids-tp5299482p5299504.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161211/283dc50b/attachment.html>
