[Qgis-user] Lat/Long Grids
Lene Fischer
lfi at ign.ku.dk
Sun Dec 11 06:09:26 PST 2016
Hi Grant,
I do understand.
At first you can choose between decimal, degree/min , Dec/min/sec. That part one of the solutions.
Secondly you can use the offset. Simply take the minutes eg 42 and divide it with 60 in the x box write 42/60. It will then change the value to 0,7 and the grid will show as you wish.
Regards
Lene Fischer
Sent: 11 December 2016 09:50
To: Lene Fischer
Subject: RE: [Qgis-user] Lat/Long Grids
Hi Lene,
I have played around with these settings but my problem is getting QGIS to plot a grid with a specific value (say 123 deg 42 min for example), not as an automatic selection (123 deg 42.7 min) based on the interval (which is in decimal degrees). Ideally what I need it to do is to plot the grid at a specific minute spacing, not a decimal degree spacing.
Hope that makes sense!
Cheers Grant
Sent: Sunday, 11 December 2016 4:45 PM
To: Grant Boxer <boxerg at iinet.net.au>; qgis-user at lists.osgeo.org
Hi Grant,
In the Print Composer>Item Properties>Map you can find Grids / Draw Grid/ Draw Coordinate
Here you can specify the CRS and the format of the coordinates.
Here a quick video for an example (Sorry forgot to turn on the mic): http://www.screencast.com/t/yy83fxLPm
Regards
Lene Fischer
From: Qgis-user [qgis-user-bounces at lists.osgeo.org] on behalf of Grant Boxer [boxerg at iinet.net.au]
Sent: 11 December 2016 07:05
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Lat/Long Grids
Is there a way to draw a geographic grid with degrees-min with exact minutes? I don't seem to be able to find the option to specify the degrees-minutes option when displaying coordinates in the map composer. I get decimal degrees-minutes with odd decimal grid values (e.g. 16deg 42.7' for example). The interval is only displayed in decimal degrees. Is there an option to specify the minute value?
Grant Boxer
Consultant Geologist (FAIG R.P. Geo)
Perth, Western Australia
Email: boxerg at iinet.net.au<mailto:boxerg at iinet.net.au>
Mobile: 0418 954 059
Skype: grantboxer
Website: www.iinet.net.au/~gboxer<http://www.iinet.net.au/~gboxer>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161211/ce2ce5de/attachment.html>
