[Qgis-user] Splitting Spatialite layers
    Ramon AndiƱach
    custard at westnet.com.au
    Sun Dec 11 18:14:16 PST 2016
Ah. Thanks.
Can I echo Richard's request for a back port?
-ramon.
> On 12 Dec. 2016, at 09:46, Randal Hale <rjhale at northrivergeographic.com> wrote:
> You're hitting a bug that exists in QGIS 2.16 and 2.18 - They are working on a resolution.
> See Below:
> http://hub.qgis.org/issues/15847
>> On 12/11/2016 08:39 PM, custard wrote:
>> Hi All,
>> As a  mostly shape/tab file user, I've been attempting to experiment with spatialite dbs a bit recently, and am starting to get a bit more used to them. I'm hitting a problem with splitting objects though, and wondered if this annoyance counted as a bug?
>> If I have a spatialite layer and split an object, that's fine. But when I save the layer I get a "Could not commit changes to layer LayerName" banner. If I press "Show more" then I get something like this:
>> _____
>> Could not commit changes to layer layername
>> Errors: SUCCESS: 1 geometries were changed.
>> SUCCESS: 1 attribute value(s) changed.
>> ERROR: 4 feature(s) not added.
>> Provider errors:
>> SQLite error: UNIQUE constraint failed: LayerName.pkuid
>> SQL: INSERT INTO "layername"("geometry","pkuid","Code","Lith","Description","Quality","code1","lith1","description1","quality1") VALUES (ST_Multi(GeomFromWKB(?, 28351)),?,?,?,?,?,?,?,?,?)
>> ____
>> I'm not populaing the pkuid data, so I think QGIS is auto filling this.
>> I think that what's happening is that when QGIS splits the feature both new parts have the same pkuid number. Certainly if I go in manually and change the field I can save without errors.
>> If QGIS is auto filling this column, ought it not be handling the splitting case too?
>> Thoughts?
>> -ramon.
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale     http://about.me/rjhale
> http://www.northrivergeographic.com/introduction-to-quantum-gis
> https://www.facebook.com/NRGSInc
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161212/d18bba51/attachment.html>
