[Qgis-user] Splitting Spatialite layers
    Nyall Dawson
    nyall.dawson at gmail.com
    Sun Dec 11 18:34:42 PST 2016
On 12 Dec 2016 13:14, "Ramon AndiƱach" <custard at westnet.com.au> wrote:
Ah. Thanks.
Can I echo Richard's request for a back port?
A backport of 3.0s fix isn't possible (it's part of a larger set of
changes). Maybe an alternative fix could be developed for 2.x, but I'm not
aware of anyone actively working on this.
Nyall
-ramon.
On 12 Dec. 2016, at 09:46, Randal Hale <rjhale at northrivergeographic.com>
wrote:
You're hitting a bug that exists in QGIS 2.16 and 2.18 - They are working
on a resolution.
See Below:
http://hub.qgis.org/issues/15847
On 12/11/2016 08:39 PM, custard wrote:
Hi All,
As a  mostly shape/tab file user, I've been attempting to experiment with
spatialite dbs a bit recently, and am starting to get a bit more used to
them. I'm hitting a problem with splitting objects though, and wondered if
this annoyance counted as a bug?
If I have a spatialite layer and split an object, that's fine. But when I
save the layer I get a "Could not commit changes to layer LayerName"
banner. If I press "Show more" then I get something like this:
_____
Could not commit changes to layer layername
Errors: SUCCESS: 1 geometries were changed.
SUCCESS: 1 attribute value(s) changed.
ERROR: 4 feature(s) not added.
Provider errors:
SQLite error: UNIQUE constraint failed: LayerName.pkuid
SQL: INSERT INTO "layername"("geometry","pkuid"
,"Code","Lith","Description","Quality","code1","lith1","description1","quality1")
VALUES (ST_Multi(GeomFromWKB(?, 28351)),?,?,?,?,?,?,?,?,?)
____
I'm not populaing the pkuid data, so I think QGIS is auto filling this.
I think that what's happening is that when QGIS splits the feature both new
parts have the same pkuid number. Certainly if I go in manually and change
the field I can save without errors.
If QGIS is auto filling this column, ought it not be handling the splitting
case too?
Thoughts?
-ramon.
Qgis-user mailing listQgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North River Geographic Systems,
Inchttp://www.northrivergeographic.com423.653.3611 <(423)%20653-3611>
twitter:rjhale
http://about.me/rjhalehttp://www.northrivergeographic.com/introduction-to-quantum-gishttps://www.facebook.com/NRGSInc
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161212/3be7d8eb/attachment.html>
