[Qgis-user] How to edit repetitive data in QGIS
Raymond Nijssen r.nijssen at terglobo.nl
Wed Dec 14 23:57:44 PST 2016
Hi Charlotte,
You can use the "dissolve" tool for merging features that have value(s)
in common. In this case the field "name" contains that value.
Go:
Vector >> Geoprocessing tools >> Dissolve...
Remove the check mark at "Dissolve all (do not use field)"
Add the field "name" to unique ID fields list
Run
This worked for me. Only drawback is that all roads without a name were
merged together. If you mind that, you can select and remove them before
running the dissolve algorithm.
Good luck,
Raymond
On 15-12-16 07:07, Matt Boyd wrote:
> Can you select the features you want by a function using the same street
> name, then
> Edit - merge selected features.
> On 15 Dec 2016 08:40, "Charlotte Wolter" <techlady at techlady.com
> <mailto:techlady at techlady.com>> wrote:
>     Hello, all,
>             I created a query for data from OpenStreetMap using
>     overpassturbo.eu <http://overpassturbo.eu>. I needed major street,
>     so used the expression highway=primary. The area was a large section
>     of Los Angeles, about 1/6th of the city, the area called South Bay.
>             I got the steeets I need, no problem. But, I also got the
>     street names repeating over and over, because the streets are broken
>     into segments by changes, such as a bridge or a change in speed
>     limit, etc., etc.
>             I am looking for a way to solve this issue, such as editing
>     the data to remove the names from some of these segments. I have
>     opened the data in the "Attributes Table," but I can't seem to edit
>     it there (which would be handy). So, if QGIS does not support
>     editing a data file, is there some other way to do it?
>             Thanks!
>     Charlotte Wolter
>     Charlotte Wolter
>     927 18th Street Suite A
>     Santa Monica, California
>     90403
>     +1-310-597-4040 <tel:%2B1-310-597-4040>
>     techlady at techlady.com <mailto:techlady at techlady.com>
>     Skype: thetechlady
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>     <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
06 25 31 49 83
