[Qgis-user] How to edit repetitive data in QGIS
Karl-Magnus Jönsson
Karl-Magnus.Jonsson at kristianstad.se
Thu Dec 15 00:32:09 PST 2016
Hi!
Instead of editing the lines or attributes with all that work you can do this in the styling. In the labels tab of the layer properties there are rendering options. There is a checkbox for merging connected lines to avoid duplicate labels. Hope this works.
Karl-Magnus Jönsson
-----Ursprungligt meddelande-----
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För Raymond Nijssen
Skickat: den 15 december 2016 08:58
Till: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] How to edit repetitive data in QGIS
Hi Charlotte,
You can use the "dissolve" tool for merging features that have value(s) in common. In this case the field "name" contains that value.
Go:
Vector >> Geoprocessing tools >> Dissolve...
Remove the check mark at "Dissolve all (do not use field)"
Add the field "name" to unique ID fields list Run
This worked for me. Only drawback is that all roads without a name were merged together. If you mind that, you can select and remove them before running the dissolve algorithm.
Good luck,
Raymond
On 15-12-16 07:07, Matt Boyd wrote:
> Can you select the features you want by a function using the same
> street name, then Edit - merge selected features.
> On 15 Dec 2016 08:40, "Charlotte Wolter" <techlady at techlady.com
> <mailto:techlady at techlady.com>> wrote:
> Hello, all,
> I created a query for data from OpenStreetMap using
> overpassturbo.eu <http://overpassturbo.eu>. I needed major street,
> so used the expression highway=primary. The area was a large section
> of Los Angeles, about 1/6th of the city, the area called South Bay.
> I got the steeets I need, no problem. But, I also got the
> street names repeating over and over, because the streets are broken
> into segments by changes, such as a bridge or a change in speed
> limit, etc., etc.
> I am looking for a way to solve this issue, such as editing
> the data to remove the names from some of these segments. I have
> opened the data in the "Attributes Table," but I can't seem to edit
> it there (which would be handy). So, if QGIS does not support
> editing a data file, is there some other way to do it?
> Thanks!
> Charlotte Wolter
> Charlotte Wolter
> 927 18th Street Suite A
> Santa Monica, California
> 90403
> +1-310-597-4040 <tel:%2B1-310-597-4040>
> techlady at techlady.com <mailto:techlady at techlady.com>
> Skype: thetechlady
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
06 25 31 49 83
