[Qgis-user] Windows bluescreen with QGIS?
Michael Schulz mandschulz at googlemail.com
Mon Feb 1 11:33:55 PST 2016
after trying several of your suggestions without big luck, I ran into the
BSOD also outside of QGIS. So, IT department changed memory as a first
plausible cause and so far, it did not reappear.
Thanks, Michael
2016-01-18 21:27 GMT+01:00 Michael Schulz <mandschulz at googlemail.com>:
> Hey Matthias and Nathan,
> thanks for your ideas. I'll look  into these and try to create a more
> detailed error description.
> Cheers,  Michael
> Am 18.01.2016 13:19 schrieb "Nathan Woodrow" <madmanwoo at gmail.com>:
>> Also note that blue screens are normally caused by bad drivers, so also
>> check recent installed drivers, printers, scanners, etc.
>> - Nathan
>> On Mon, Jan 18, 2016 at 10:09 PM, Matthias Kuhn <matthias at opengis.ch>
>> wrote:
>>> Hi Michael,
>>> This sounds severe, but from the information provided so far it is very
>>> hard to tell what could possibly be the cause for this.
>>> You could try a couple of things:
>>>  * Check the memory usage while it happens [1]
>>>  * Disable all plugins, delete the local qgis configuration folder
>>>  * Provide information about the projects which cause the issue (is
>>> there a special data provider, extremely big dataset, special styling...
>>> involved).
>>>  * Update your Windows with all the latest patches and updates (you will
>>> probably have to ask your local IT service if they have done / will do that
>>> for you)
>>> Best regards,
>>> Matthias
>>> [1]
>>> http://windows.microsoft.com/en-us/windows7/view-how-much-memory-your-computer-is-using
>>> On 01/18/2016 12:52 PM, Michael Schulz wrote:
>>> Dear users,
>>> I keep having an issue since one week, that when using QGIS 2.12(.2) /
>>> 2.10 with some projects, my PC crashes with a windows blue screen (Win7 64
>>> Pro). Sometimes a bad_pool_header or system_service_exception error. I'm
>>> not saying this is caused by QGIS, but it is (more or less) reproducible
>>> and doesn't happen when I'm not using QGIS.
>>> I wonder if this could somehow be related to QGIS specifically, or if it
>>> is a memory issues (hardware failure). Problem is that I'm in a company
>>> network with quiet restricted access to my machine. I was wondering whether
>>> someone could give me a hint or suggestions, where I could start looking
>>> into this.
>>> Thanks, Michael
>>> Michael Schulz
>>> Qgis-user mailing listQgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Matthias Kuhn
>>> OPENGIS.ch - https://www.opengis.ch
>>> Spatial • (Q)GIS • PostGIS • Open Source
Michael Schulz
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160201/2913b461/attachment.html>
