[Qgis-user] New Shapefile Features Fail to Save
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Feb 2 19:04:01 PST 2016
I have done this in the past without errors in QGIS.  I would upgrade to the latest version. Then to figure out where the problem is, I would:
Make sure that both layer are polygon layers (and not lines and polygons), that both have the same CRS (along with the project CRS), that both have the same fields and that the "receiving layer" is in editing mode, and saved subsequently. I would limited the amount of open files and open plugins.
Try  copying polygons from a newly created file to an empty newly created layer in QGIS and not a shapefile that was previously manipulated in other softwares.  All this could help you find the source of the problem.
I would also look at the bug reports to see if it is an issue for that version.
Hope this helps.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Feb 2, 2016 8:46 PM, "Springfield Harrison [via OSGeo.org]	" <ml-node+s1560n5248589h20 at n6.nabble.com> wrote:
Hello Group,
        Am using
QGIS 2.10.1 and have done so without significant problems for many
months.  I am attempting to create simple polygons in a shapefile by
direct vertex entry or copying polygons from another shapefile layer and
pasting them into the active layer.
        In almost
every case, these features disappear.  There is an entity entry in
the attribute table but there are no polygons created.  In one case
a polygon was created but it was not the shape that I digitized; no more
polygons could be created although the process for doing so appears to be
working.  No error messages were created.  The CRS for the
project and the shapefile are the same.
        The
shapefile can be opened in another GIS but has no content.
        Here are
some product details:  QGIS version  2.10.1-Pisa  QGIS
code revision
d20c5b7
        Thanks
very much for any help you can render, Cheers . . . . . . . . Springfield
Harrison
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/FW-QGIS-crashes-when-using-mouse-wheel-to-zoom-in-and-out-of-WMTS-services-tp5248434p5248589.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/FW-QGIS-crashes-when-using-mouse-wheel-to-zoom-in-and-out-of-WMTS-services-tp5248434p5248593.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160202/b17fb35f/attachment.html>
