[Qgis-user] New Shapefile Features Fail to Save
Springfield Harrison
stellargps at gmail.com
Tue Feb 2 22:29:57 PST 2016
Thanks for those ideas. I can check off most of those items except
upgrading. This is new development so likely computer based? Rather than
QGIS.
I'll look at the bug reports; this is a pretty serious error. Thank you .
Cheers . . . . . Spring
Samsung Tab 4
On Feb 2, 2016 7:15 PM, "Nicolas Cadieux" <nicolas.cadieux at archeotec.ca>
wrote:
> Hi,
> I have done this in the past without errors in QGIS. I would upgrade to
> the latest version. Then to figure out where the problem is, I would:
> Make sure that both layer are polygon layers (and not lines and polygons),
> that both have the same CRS (along with the project CRS), that both have
> the same fields and that the "receiving layer" is in editing mode, and
> saved subsequently. I would limited the amount of open files and open
> plugins.
> Try copying polygons from a newly created file to an empty newly created
> layer in QGIS and not a shapefile that was previously manipulated in other
> softwares. All this could help you find the source of the problem.
> I would also look at the bug reports to see if it is an issue for that
> version.
> Hope this helps.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> www.archeotec.ca
> On Feb 2, 2016 8:46 PM, "Springfield Harrison [via OSGeo.org] " <[hidden
> email] <http:///user/SendEmail.jtp?type=node&node=5248593&i=0>> wrote:
> Hello Group,
> Am using QGIS 2.10.1 and have done so without significant problems
> for many months. I am attempting to create simple polygons in a shapefile
> by direct vertex entry or copying polygons from another shapefile layer and
> pasting them into the active layer.
> In almost every case, these features disappear. There is an
> entity entry in the attribute table but there are no polygons created. In
> one case a polygon was created but it was not the shape that I digitized;
> no more polygons could be created although the process for doing so appears
> to be working. No error messages were created. The CRS for the project
> and the shapefile are the same.
> The shapefile can be opened in another GIS but has no content.
> Here are some product details: QGIS version 2.10.1-Pisa QGIS
> code revision d20c5b7 <https://github.com/qgis/QGIS/commit/d20c5b7>
> Thanks very much for any help you can render, Cheers . . . . . . .
> . Springfield Harrison
> Qgis-user mailing list
> <a
> href="/user/SendEmail.jtp?type=node&node=5248589&i=0">[hidden
> email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/FW-QGIS-crashes-when-using-mouse-wheel-to-zoom-in-and-out-of-WMTS-services-tp5248434p5248589.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
> here.
> <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
> style="font:9px serif">NAML
> View this message in context: Re: New Shapefile Features Fail to Save
> <http://osgeo-org.1560.x6.nabble.com/FW-QGIS-crashes-when-using-mouse-wheel-to-zoom-in-and-out-of-WMTS-services-tp5248434p5248593.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160202/06cc36a4/attachment.html>
