[Qgis-user] Open attribute table in form view by default
Andreas Neumann
a.neumann at carto.net
Mon Feb 8 05:00:27 PST 2016
Hi Stefan,
I don't know such a setting. And no - you did not overlook it.
The only tool that opens the form view by default is the identify tool -
if the checkbox is enabled that opens the form if there only one target.
But then you can't easily switch to the table view.$
Andreas
On 08.02.2016 13:19, Blumentrath, Stefan wrote:
> Hi,
> Is there a setting where I can specify that an attribute table should
> be opened in form view by default?
> I tried searched both Layer properties and Setting options but did not
> find anything. Did I simply overlook it?
> Cheers
> Stefan
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160208/fe5db0df/attachment.html>
