[Qgis-user] Open attribute table in form view by default
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Mon Feb 8 05:12:40 PST 2016
Hi Andreas,
Thanks for your answer!
My use case is using QGIS as DB frontend where also non-spatial layers have to be edited and editing does not necessarily start with a geometry...
Would you consider having such a setting a relevant enhancement? If so, should I open an enhancement ticket or add a comment to Matthias`s “Fields and Forms redesign”: https://github.com/qgis/QGIS-Enhancement-Proposals/issues/37
Cheers
Stefan
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: 8. februar 2016 14:00
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Open attribute table in form view by default
Hi Stefan,
I don't know such a setting. And no - you did not overlook it.
The only tool that opens the form view by default is the identify tool - if the checkbox is enabled that opens the form if there only one target. But then you can't easily switch to the table view.$
Andreas
On 08.02.2016 13:19, Blumentrath, Stefan wrote:
Is there a setting where I can specify that an attribute table should be opened in form view by default?
I tried searched both Layer properties and Setting options but did not find anything. Did I simply overlook it?
Cheers
Stefan
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160208/a116f441/attachment.html>
