[Qgis-user] Open attribute table in form view by default
Andreas Neumann
a.neumann at carto.net
Mon Feb 8 05:37:05 PST 2016
Hi Stefan,
I think it would be a useful setting to have "per layer".
The QEP you mention is primarily about making the fields settings tab
easier to use / splitting it up in two separate tabs. Perhaps it would
be more useful to open a feature request for that (if none exists so
far) than adding it to the QEP - which seems to deal with different issues.
If this important to you - please consider sponsoring a dev to implement
this. It can't be very complicated to implement.
For the next QGIS release we will also contract with Matthias to do
several enhancements to transactions/relations, forms and widgets. I can
send you more details if you are interested.
Andreas
On 08.02.2016 14:12, Blumentrath, Stefan wrote:
> Hi Andreas,
> Thanks for your answer!
> My use case is using QGIS as DB frontend where also non-spatial layers
> have to be edited and editing does not necessarily start with a
> geometry...
> Would you consider having such a setting a relevant enhancement? If
> so, should I open an enhancement ticket or add a comment to Matthias`s
> “Fields and Forms redesign”:
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/37
> Cheers
> Stefan
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Andreas Neumann
> *Sent:* 8. februar 2016 14:00
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Open attribute table in form view by default
> Hi Stefan,
> I don't know such a setting. And no - you did not overlook it.
> The only tool that opens the form view by default is the identify tool
> - if the checkbox is enabled that opens the form if there only one
> target. But then you can't easily switch to the table view.$
> Andreas
> On 08.02.2016 13:19, Blumentrath, Stefan wrote:
> Hi,
> Is there a setting where I can specify that an attribute table
> should be opened in form view by default?
> I tried searched both Layer properties and Setting options but did
> not find anything. Did I simply overlook it?
> Cheers
> Stefan
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160208/4fea3c44/attachment.html>
