[Qgis-user] [QGis 2.10]Error while saving shape file
Pierre Muckensturm
pierre at georezo.net
Mon Feb 8 06:37:33 PST 2016
I only saw your answer after Bernhard's. Holy crap. It is a serious issue.
I really hope someone will manage to find an answer.
Le 8 févr. 2016 15:08, "Uwe Fischer" <gisfisch at t-online.de> a écrit :
> Pierre,
> this is now the third message in this list concerning fatal errors in
> editing shapefiles in QGIS within a few weeks (see details below). Maybe
> it’s not a consolation to you, but others lost a lot of confidence in QGIS,
> too. Looks like there are bugs that are very difficult to remove. It’s a
> pity that there is no information on the debugging status.
> Regards,
> Uwe
> On Feb 2, 2016 8:46 PM, "Springfield Harrison [via OSGeo.org] " <[hidden
> email] <http://user/SendEmail.jtp?type=node&node=5248593&i=0>> wrote:
> Hello Group,
> Am using QGIS 2.10.1 and have done so without significant problems
> for many months. I am attempting to create simple polygons in a shapefile
> by direct vertex entry or copying polygons from another shapefile layer and
> pasting them into the active layer.
> In almost every case, these features disappear. There is an
> entity entry in the attribute table but there are no polygons created. In
> one case a polygon was created but it was not the shape that I digitized;
> no more polygons could be created although the process for doing so appears
> to be working. No error messages were created. The CRS for the project
> and the shapefile are the same.
> The shapefile can be opened in another GIS but has no content.
> Here are some product details: QGIS version 2.10.1-Pisa QGIS
> code revision d20c5b7 <https://github.com/qgis/QGIS/commit/d20c5b7>
> Thanks very much for any help you can render, Cheers . . . . . . .
> . Springfield Harrison
> Qgis-user mailing list
> Hello all,
> today I was working on a shape dataset and I had to delete some features.
> Later I opened the shapefile in ArcMap by chance and I found that the
> features were not deleted. They still did exist. I repeated the process –
> and got the same result. Then, searching the internet, I found this
> incredible post: https://hub.qgis.org/issues/11007
> It is a well known problem (for 1,5 years!!) that *QGIS is not able to
> delete shapes in a reliable way*!! I was horrified to read this because
> it is the same as if a Word processor would not be able to delete a letter
> from a text. I cannot understand why the QGIS developers haven’t fix that
> yet. If QGIS really wants to compete with ArcMap, they should fix it as
> soon as possible. At least, the according menu entries or buttons should be
> inactivated if they don’t bring out reliable results.
> My questions are:
> · is this information still up to date? I can‘t read all of the
> 80 answers to the post now to get in-depth information ...
> · does anybody have information about how they are planning to
> handle this problem at the development team?
> · is there a workaround for this? Do the GRASS vector tools bring
> out reliable results?
> · are there more of those software errors in QGIS that might lead
> to huge problems in working on vector data and sharing them with others? If
> so, is there a „black list“ of things one is never allowed to use in QGIS
> if you don’t want to destroy your datasets?
> *Von:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *Im Auftrag
> von *Pierre Muckensturm
> *Gesendet:* Montag, 8. Februar 2016 14:34
> *An:* Qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] [QGis 2.10]Error while saving shape file
> Hi,
> I use a QGis 2.10 version, X64 on Windows installed with Osgeo4W.
> I'll try to explain the bug.
> I work on a map, with a shape file of polygons. They are not really
> complex, nor numerous (25). I got id, DOSSIER, NOM_OPERAT,
> PRIORITE, COMMENTA, DATE_MAJ, SOURCE, LIBELLE_X, LIBELLE_Y
> fields and SURF_HA which is a virtual field.
> Friday, it took me 5 min to save the file each time I modify a vertex.
> Today, I update my id field with the expression "$id". Then, my shape file
> looks like a totally mess (look at the imgur album :
> http://imgur.com/a/noSM2). The LIBELLE_X, LIBELLE_Y fields have
> disappeard, the DOSSIER field which used to be null is now partially
> fulled, the NOM_OPERAT are truncated, fulled in a completelly non-sense
> manner. As for PRIORITE, DATE_MAJ.
> Conclusion, 2 days of work in a trash. I'm quite pissed off, according
> with the fact that I'm trying to convince my superior we shall use QGis.
> So, what happened ? How could this happen ? Sorry but I don't have the
> genuine files, and the data are quite sensitive.
> PLM
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160208/c3a3fa93/attachment.html>
