[Qgis-user] ARCGIS Geodatabase import raster
    Alex M
    tech_dev at wildintellect.com
    Mon Feb  8 16:13:18 PST 2016
On 02/08/2016 03:51 PM, Grant Boxer wrote:
> Thank you for the information on the geodatabase files. It appears my
> problem might be that the geodatabase files I am trying to open are raster
> files. I can now open geodatabase vector files no problem - thanks to
> everyone's input. Should raster files also open, or is there a different
> process required?
> Grant Boxer
> Consultant Geologist (FAIG R.P. Geo)
> Perth, Western Australia
Rasters inside File Geodatabase are not currently supported by either
the OpenFileGDB or the ESRI FileGDB drivers of GDAL. Unfortunately you
will need to find someone with a copy of Arc to convert those out to
formats that can be used.
-Alex
