[Qgis-user] [GRASS-user] QGIS - GRASS Plugin not loading
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Tue Feb 9 00:26:10 PST 2016
Moin Jürgen,
If you don`t mind, yet another question:
Latest qgis-dev package on http://download.osgeo.org/osgeo4w/x86/release/qgis/qgis-dev/ is:
qgis-dev-2.13.0-93.tar.bz2
But through OSGeo4W I can only install the two days old version 2.13.0-91. I downloaded the osgeo4w-setup-x86.exe again but that did not change anything. The setup.ini is still from 06.02.2016... Is there a way to install 2.13.0-93 already now, or do I have to wait just a little more?
Cheers
Stefan
P.S.: I hope you bear with my impatience, I am just eager to see the temporal GRASS modules work properly on Windows too.
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: 8. februar 2016 14:38
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] [GRASS-user] QGIS - GRASS Plugin not loading
Hi Stefan,
On Mon, 08. Feb 2016 at 13:19:07 +0000, Blumentrath, Stefan wrote:
> Just a swift note:
> I saw that yesterday`s nightly build on OSGeo4W seems to be numbered incorrectly and has 0 byte...
That's also wrong ;) -84 was a week old and hence was truncated. -92 is the
latest build.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
