[Qgis-user] custom string formatting for grid coordinate labels
Neumann, Andreas
a.neumann at carto.net
Wed Feb 17 02:04:55 PST 2016
That's an excellent idea - thanks for sharing!
Andreas
On 2016-02-17 10:42, Andrew Harfoot wrote:
> Hi Uwe,
> If you can't use formatting tags, then possibly Unicode is your friend here - have a look at characters U1D31 and U1D3A - superscript E and N respectively. Using these should allow you to generate labels like this: 0234ᴱ or 345389ᴺ
> Cheers,
> Andy
> On 16/02/2016 18:48, Nyall Dawson wrote:
>> On 17 Feb 2016 2:20 AM, "Uwe Fischer" <gisfisch at t-online.de> wrote:
>>> Hello List, hello Nyall,
>>> I have a question concerning the grid coordinate labels for map frames in print composer. If you set the label format to „custom", you get to „Expression based annotation" box where you can build expressions for formatting, e.g. concat(left(@grid_number,3) , '<sup>E'). That works fine in the editor and the footnote preview shows exactly the desired result (E as an above positioned little index). But, in the map composer canvas, the format string is rendered as text, that means <sup>E shows up as a text string there.
>>> Is there a way to apply the format rule (which seems to work) correctly to the map composer?
>> Not currently - there's no support for formatting in the coordinate text.
>> Nyall
>>> Regards and thanks a lot,
>>> Uwe
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andy Harfoot
> GeoData Institute
> University of Southampton
> Southampton
> SO17 1BJ
> Tel: +44 (0)23 8059 2719
> Fax: +44 (0)23 8059 2849
> www.geodata.soton.ac.uk [1]
Links:
[1] http://www.geodata.soton.ac.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160217/3311ff49/attachment.html>
