[Qgis-user] style files
Richard McDonnell
richard.mcdonnell at opw.ie
Fri Feb 19 03:38:40 PST 2016
Kyle,
My experience with spatial lite is limited, but When working with PostgreSQL (PostGIS), you can save the style to the database, not sure if this is only available in PostgreSQL.
Might I also suggest you send the QGIS Project File, this will keep all the styling for you, and as long as the other users open it in QGIS.
Regards,
Richard.
On 18/02/2016 22:15, Alex M wrote:
> Please keep conversation on list.
> So did you try saving 1 style per table to the db? I don't think there's
> any benefit to the shapefile route. Now if you want to create the style
> once, and then copy it for each table, that might be a little trickier
> but probably possible with a little bit of crafty SQL. Or the manual
> way, copy style - paste style - save style.
> Thanks,
> Alex
> On 02/18/2016 02:13 PM, Kyle T. Kouri wrote:
>> So I have been experimenting for past few days. Save as default does not seem
>> to work with one file and multiple tables. But once i go to lets say a shape
>> file that has one table it works perfect. I think I am stuck at having a bunch
>> of shape files instead of one DB file with multiple tables.
>> On Thu, Feb 18, 2016 04:25 PM, Alex M <tech_dev at wildintellect.com> wrote:
>> On 02/18/2016 12:44 PM, Kyle T. Kouri wrote:
>>>> Hello all,
>>>> I have a spatial lite db file that has 15 tables in it. I am trying to
>>> figure
>>>> out a way to create style files for each table and then when ever I open
>>> this
>>>> the styles are saved with it. Right now I have to open one at a a time for
>>>> each table in the spatial lite DB. My goal is to have multiple .sl3 db
>>> files
>>>> with the same tables (different data) for each of the national
>>> parks in the
>>>> USA. But when I send the data out people can just open up the .sl3 file in
>>>> QGIS and see the style the way I want set it. So they dont also have to
>>> load
>>>> all the .qml or .sld files.
>>>> Kyle Todd Kouri
>>> This is the closest thing I know of
>>> https://pvanb.wordpress.com/2014/05/15/saving-layer-styles-to-your-spatialite-database/
>>> I was wondering what would happen if you had multiple styles for the
>>> same layer, and I think the Save as Default style box is the key there.
>>> Otherwise I would save QGIS projects, and send the project file with the
>>> data, and tell users to open the projects.
>>> You could potentially write a plugin that does the autoloading of
>>> associated styles and tables too.
>>> Enjoy,
>>> Alex
>> Kyle Todd Kouri
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160219/abec191a/attachment.html>
