[Qgis-user] Import lines from cvs
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed Jan 6 12:25:44 PST 2016
I think you will need to use the python console to do the job.  I have no direct  experience but if you look in the pyqgis developer cookbook and look for "Geometry Construction" you will find a reference to "gLine".
With that, you can create a line with two or more points.
Before doing that, look at the plugin (activate experimental plugin and Search for " line".  There seems to be po plugins that can do it like PointConnector or Points2One...
Good luck.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Jan 6, 2016 2:58 PM, "Joris Hintjens [via OSGeo.org]	" <ml-node+s1560n5244005h16 at n6.nabble.com> wrote:
	Hello,
I’m lost.
I have a list of movements. A table with (among others) a column “FROM”  and a column “TO” (both containing coordinates)
How can I import this in QGIS so that I have a bunch of lines going from FROM to TO?
thanks for your comments
Joris
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Import-lines-from-cvs-tp5244005.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Import-lines-from-cvs-tp5244005p5244012.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160106/b47a594a/attachment.html>
