[Qgis-user] Import lines from cvs
    Nyall Dawson
    nyall.dawson at gmail.com
    Wed Jan  6 17:47:56 PST 2016
On 7 January 2016 at 07:08, Joris Hintjens <jorishin at gmail.com> wrote:
> Hello,
> I’m lost.
> I have a list of movements. A table with (among others) a column “FROM”  and a column “TO” (both containing coordinates)
> How can I import this in QGIS so that I have a bunch of lines going from FROM to TO?
This is relatively straightforward in QGIS master:
- import your CSV file
- right click the CSV layer, and choose "Save as"
- change format to "ESRI Shapefile". Choose the correct CRS for your
coordinates.
- expand out the "Geometry" group and change "Geometry type" from
"Automatic" to "LineString"
- click OK, the new LineString shapefile (with all null geometries)
will be added to the project
- now, you need to create the geometries. This is done through the
field calculator.
- tick "update existing field"
- change the field to "<geometry>"
- enter the expression:
'make_line(make_point("x1","y1"),make_point("x2","y2"))' (but replace
x1, y1, ... with the correct columns names from your original CSV
file)
- click OK. Done!
Nyall
> thanks for your comments
> Joris
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
