[Qgis-user] Import lines from cvs
Nathan Woodrow madmanwoo at gmail.com
Wed Jan 6 18:08:58 PST 2016
Or use excel to make a WKT column and import that.
Nathan
On Thu, 7 Jan 2016 11:48 am Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 7 January 2016 at 07:08, Joris Hintjens <jorishin at gmail.com> wrote:
> > Hello,
> > I’m lost.
> > I have a list of movements. A table with (among others) a column “FROM”
> and a column “TO” (both containing coordinates)
> > How can I import this in QGIS so that I have a bunch of lines going from
> FROM to TO?
> This is relatively straightforward in QGIS master:
> - import your CSV file
> - right click the CSV layer, and choose "Save as"
> - change format to "ESRI Shapefile". Choose the correct CRS for your
> coordinates.
> - expand out the "Geometry" group and change "Geometry type" from
> "Automatic" to "LineString"
> - click OK, the new LineString shapefile (with all null geometries)
> will be added to the project
> - now, you need to create the geometries. This is done through the
> field calculator.
> - tick "update existing field"
> - change the field to "<geometry>"
> - enter the expression:
> 'make_line(make_point("x1","y1"),make_point("x2","y2"))' (but replace
> x1, y1, ... with the correct columns names from your original CSV
> file)
> - click OK. Done!
> Nyall
> > thanks for your comments
> > Joris
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160107/29548154/attachment.html>
