[Qgis-user] Processing>QGIS>Clip
Victor Olaya
volayaf at gmail.com
Sun Jan 10 23:22:00 PST 2016
The translated output name is not used for the filename, but only to
set the name in the layer list, so it's not likely to cause issues.
Could you share the content of the Processing log, if any, or any test
data so we can try to reproduce the error?
Thanks!
2016-01-09 23:49 GMT+01:00 Lene Fischer <lfi at ign.ku.dk>:
> I found the error – it is when I run Processing in Danish – It translate the
> temp layer into ‘Beskåret’ and then no result. Non Ascii char.
> Normally I work in English version while using the Processing. Next week the
> users has asked for the Danish version.
> Regards
> Lene
> Fra: anita.graser.at at gmail.com [mailto:anita.graser.at at gmail.com] På vegne
> af Anita Graser
> Sendt: 9. januar 2016 22:42
> Til: Lene Fischer
> Cc: qgis-user at lists.osgeo.org
> Emne: Re: [Qgis-user] Processing>QGIS>Clip
> On Sat, Jan 9, 2016 at 10:14 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
> Hi,
> Just sitting and updating my tutorials to 2.12.2 on windows 64 bit
> Using the function Processing>QGIS>Clip
> It gives no result - If I use the same function from Vector>Geoprocessing
> tools>Clip it works fine.
> Searched at Nabble and found no bug-reports.
> Can anyone confirm the problem, the I file a Bugreport.
> Hi Lene,
> Processing>QGIS>Clip worked for me in a quick test in 2.12.2 and dev 2.13.
> Can you maybe share the data to reproduce?
> Best wishes,
> Anita
> Regards
> Lene Fischer
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
