[Qgis-user] Processing>QGIS>Clip
Lene Fischer
lfi at ign.ku.dk
Sat Jan 9 14:49:03 PST 2016
I found the error – it is when I run Processing in Danish – It translate the temp layer into ‘Beskåret’ and then no result. Non Ascii char.
Normally I work in English version while using the Processing. Next week the users has asked for the Danish version.
Regards
Lene
Fra: anita.graser.at at gmail.com [mailto:anita.graser.at at gmail.com] På vegne af Anita Graser
Sendt: 9. januar 2016 22:42
Til: Lene Fischer
Cc: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Processing>QGIS>Clip
On Sat, Jan 9, 2016 at 10:14 PM, Lene Fischer <lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>> wrote:
Just sitting and updating my tutorials to 2.12.2 on windows 64 bit
Using the function Processing>QGIS>Clip
It gives no result - If I use the same function from Vector>Geoprocessing tools>Clip it works fine.
Searched at Nabble and found no bug-reports.
Can anyone confirm the problem, the I file a Bugreport.
Hi Lene,
Processing>QGIS>Clip worked for me in a quick test in 2.12.2 and dev 2.13.
Can you maybe share the data to reproduce?
Best wishes,
Anita
Regards
Lene Fischer
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160109/9893f356/attachment.html>
