[Qgis-user] troubles with QGis Atlas
Nyall Dawson
nyall.dawson at gmail.com
Mon Jan 11 17:01:45 PST 2016
On 12 Jan 2016 8:36 AM, "didier peeters" <dpeeter1 at ulb.ac.be> wrote:
> Thank you Nyall.
> Oh, this could be the reason. To clarify a little bit, my field is not
called « id » and my coverage layer is a Postgis table, the field I use has
a PK and the geometry layer is a Postgis view with numerical values that I
represent with proportional circles.
> Does it mean that what I want to do is not possible ? Or should I use
another data source ?
It should be possible. Can you share a few rows from both tables?
Nyall
> Didier
> > Le 11 janv. 2016 à 21:26, Nyall Dawson <nyall.dawson at gmail.com> a écrit
> > On 12 January 2016 at 02:18, didier peeters <dpeeter1 at ulb.ac.be> wrote:
> >> Hello,
> >> I’ve started to use the Atlas in QGis composer: I use a non-geometry
table
> >> as coverage layer, providing the feature id’s and corresponding labels
for
> >> my maps, and I display always the same extent but with different data
of
> >> course, using a rule-based style like ‘ "field" = @atlas_featureid'.
At
> >> first it worked fine but now, the atlas mistakes @atlas_featurenumber
for
> >> @atlas_featureid, i.e. instead of displaying the data corresponding to
the
> >> feature id it displays the data corresponding to the number of the
feature
> >> (~ the row number, as some are filtered out), but selects properly the
> >> labels corresponding to the feature value. So I obtain maps with a
title
> >> which is not related to the content !
> >> In the expression editor @atlas_featureid and @atlas_featurenumber are
> >> previewed with the same Current value although they are different !
> >> Does anyone have an idea about this ?
> > Keep in mind that feature id's might not be predictable, depending on
> > your data source. They aren't user visible, and as such aren't
> > suitable for a join like this.
> > Did you mean instead to use a field called "id" from your coverage
layer?
> > Nyall
> >> I use QGis 2.12.1 on Mac.
> >> Didier
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160112/305792d4/attachment.html>
