[Qgis-user] Hillshading while ignoring coastline / elevation below X m?
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Jan 12 07:15:30 PST 2016
I think you need to create a mask. The easiest way is to use the raster calculator to create this mask on the DEM.
For example, if you use something like dem.tiif>10, then pixel bigger than 10 will be given the value of 1 and others will have the value of 0. Then you take this mask and multiply it with the hillshade.
Good luck
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jan 12, 2016 9:35 AM, "Sebastian Stüwe [via OSGeo.org] " <ml-node+s1560n5244740h1 at n6.nabble.com> wrote:
Dear group, I am creating a physical map for my school, but the hillshading, which otherwise looks quite satisfactory, does something I hadn’t thought about: it shades the coastline. Is there a way to tell QGIS that it should only create a hillshade file for elevations greater than X m? Thanks. Sebastian.
— Lutheran Church in Liberia Sebastian Stüwe, MEd Consultant LCLSS Deputy Director CED P.O. Box 10-1046 13th street/Sinkor Monrovia Liberia +231 775 127409 +49 176 63672480
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user signature.asc (859 bytes) Download Attachment
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Hillshading-while-ignoring-coastline-elevation-below-X-m-tp5244740.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Hillshading-while-ignoring-coastline-elevation-below-X-m-tp5244740p5244761.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160112/fbd78def/attachment.html>
