[Qgis-user] FW: Custom CRS problem
Andre Joost
andre+joost at nurfuerspam.de
Wed Jan 13 07:19:53 PST 2016
Hi Keith,
it would have been better to answer to the list, so that others can
benefit from the answers too.
There are many bugs related to the Print Composer and the OpenLayers
plugin. So I adivise you to switch to the QuickMap Services plugin, and
see if the problem remains.
Personally, I do not use the print composer, so I can't help on matters
related to it.
HTH,
André Joost
Am 11.01.2016 um 13:35 schrieb Keith Bates:
> Thanks André
> The project CRS is EPSG 3857 as I'm using OpenStreetMap as the base.
> I kept this layer as EPSG:3857 and then loaded the Print Composer. I
> then selected my custom grid (exactly the same as EPSG:27700 to test
> it and then amend it to my local grid when it works). I do have on
> the fly projection turned on too. The x and y formats are 10000.
> However, the grid lines aren't in 10km spacings (they seem about
> 8km), they're exactly horizontal and vertical. Take London as an area
> that I'm showing in the Print Composer, x=0 passes straight through
> the 0 degree latitude and the northing running roughly through London
> (along the Thames) shows as y=6700000.00.
> Just to reconfirm, the test local grid information is exactly the
> same as EPSG:27700. That's the puzzling bit, EPSG:27700 works
> perfectly, but the local grid with the exact same information does
> not.
> Hope that provides a bit more information, would be easier to provide
> an image but not sure how. Many thanks!
> Keith
> -----Original Message----- From: Qgis-user
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andre Joost
> Sent: 11 January 2016 12:21 To: qgis-user at lists.osgeo.org Subject:
> Re: [Qgis-user] FW: Custom CRS problem
> Am 11.01.2016 um 12:08 schrieb Keith Bates:
>> I can't seem to be able to add a custom CRS that shows correctly,
>> using version 2.12.1-Lyon on Windows.
>> Any help would be appreciated as I really can't work this out!
>> Thanks.
> You have to add some more information to make the problem
> understandable:
> What source CRS does your data have? Did you assign the custom
> projection, or reprojected the data to it? What extent does your data
> have in the Custom CRS? Why can't you use EPSG:27700? Can you give
> sample coordinates of what you got and what you want to get?
> Greetings, André Joost
> _______________________________________________ Qgis-user mailing
> list Qgis-user at lists.osgeo.org List info:
> http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe:
Gruß,
André Joost
