[Qgis-user] Problems with clipper and snappin options
Ramon AndiƱach
custard at westnet.com.au
Sun Jan 17 22:08:12 PST 2016
I think the listsever has (deliberately) dropped your images.
Two suggestions:
1. Can you check and make sure that both your layers have the same CRS?
If they aren't your first move should be to save one of the layers so they have the same CRS.
2. On the snapping settings, change the snapping mode to "Advanced" (Avanzado?). This allows you to set options for individual layers.
Hope this helps.
-ramon.
> On 18 Jan 2016, at 13:17, Mariana Buzzi <marianabuzzi86 at gmail.com> wrote:
> Good night people!
> I'm making masks that correspond to landscape units (LU). The polygon corresponds to the LU called pampas. This polygon was done through the creation of a vector and scanned with mouse function of landscape features shape. As you can see, my first problem emerges at that I can not cut the pampa (light blue) with clipper program.
> The second problem arises with me snnapping options. I need to do two polygons .. rudimentary scanning did not want to, but I wanted to use the snapping options so that the edges are accurate. But I could not.
> I hope you can help me.
> Thank you.
> A big hello from Patagonia.
> Mariana
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
