[Qgis-user] Problems with clipper and snappin options
Mariana Buzzi
marianabuzzi86 at gmail.com
Mon Jan 18 19:28:46 PST 2016
Hi Ramon!
I check to the CRS and this is right!i can't use the clip option,may be is
because I did the mask with the option raster to vectorial. I don't
know!!!!what can I do?
I can do the advance digital!!!!
Thanks so much!!!!
Regards
Mariana
El 18/01/2016 03:44, "Ramon Andiñach" <custard at westnet.com.au> escribió:
> Hi,
> I think the listsever has (deliberately) dropped your images.
> Two suggestions:
> 1. Can you check and make sure that both your layers have the same CRS?
> If they aren't your first move should be to save one of the layers so
> they have the same CRS.
> 2. On the snapping settings, change the snapping mode to "Advanced"
> (Avanzado?). This allows you to set options for individual layers.
> Hope this helps.
> -ramon.
> > On 18 Jan 2016, at 13:17, Mariana Buzzi <marianabuzzi86 at gmail.com>
> wrote:
> > Good night people!
> > I'm making masks that correspond to landscape units (LU). The polygon
> corresponds to the LU called pampas. This polygon was done through the
> creation of a vector and scanned with mouse function of landscape features
> shape. As you can see, my first problem emerges at that I can not cut the
> pampa (light blue) with clipper program.
> > The second problem arises with me snnapping options. I need to do two
> polygons .. rudimentary scanning did not want to, but I wanted to use the
> snapping options so that the edges are accurate. But I could not.
> > I hope you can help me.
> > Thank you.
> > A big hello from Patagonia.
> > Mariana
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160119/05e98a47/attachment.html>
