[Qgis-user] Windows bluescreen with QGIS?
Nathan Woodrow
madmanwoo at gmail.com
Mon Jan 18 04:18:36 PST 2016
Also note that blue screens are normally caused by bad drivers, so also
check recent installed drivers, printers, scanners, etc.
- Nathan
On Mon, Jan 18, 2016 at 10:09 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Michael,
> This sounds severe, but from the information provided so far it is very
> hard to tell what could possibly be the cause for this.
> You could try a couple of things:
> * Check the memory usage while it happens [1]
> * Disable all plugins, delete the local qgis configuration folder
> * Provide information about the projects which cause the issue (is there
> a special data provider, extremely big dataset, special styling...
> involved).
> * Update your Windows with all the latest patches and updates (you will
> probably have to ask your local IT service if they have done / will do that
> for you)
> Best regards,
> Matthias
> [1]
> http://windows.microsoft.com/en-us/windows7/view-how-much-memory-your-computer-is-using
> On 01/18/2016 12:52 PM, Michael Schulz wrote:
> Dear users,
> I keep having an issue since one week, that when using QGIS 2.12(.2) /
> 2.10 with some projects, my PC crashes with a windows blue screen (Win7 64
> Pro). Sometimes a bad_pool_header or system_service_exception error. I'm
> not saying this is caused by QGIS, but it is (more or less) reproducible
> and doesn't happen when I'm not using QGIS.
> I wonder if this could somehow be related to QGIS specifically, or if it
> is a memory issues (hardware failure). Problem is that I'm in a company
> network with quiet restricted access to my machine. I was wondering whether
> someone could give me a hint or suggestions, where I could start looking
> into this.
> Thanks, Michael
> Michael Schulz
> Qgis-user mailing listQgis-user at lists.osgeo.org
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160118/71a7f8dd/attachment.html>
