[Qgis-user] QGIS big fail in deleting Shapes!!
Even Rouault
even.rouault at spatialys.com
Wed Jan 20 01:23:15 PST 2016
Le mercredi 20 janvier 2016 09:04:52, Neumann, Andreas a écrit :
> Hi,
> Regarding GDAL update to version 2.0: if your platform is Windows, I
> already asked Jürgen if he can update to version 2.0 - as there are
> other issues/new functionality that would be enabled by moving to GDAL
> 2.0 (like better Geopackage support, curve support (for Interlis and
> later also Geopackage) and probably some other improvements). So there
> is a good chance that QGIS 2.14 on Windows will ship with GDAL 2.0.
FYI, GDAL 2.0.2 RC1 should be out for the end of the week.
> @Uwe: while I totally agree that this is a severe error that should be
> fixed, apparently it isn't that easy. And I can only recommend that you
> should not build your GIS projects around Shapefiles. There are other
> options around, like Postgis, SpatiaLite or Geopackage that also allows
> to share data with ArcGIS. And you could also store and edit your data
> in SpatiaLite, Postgis or Geopackage and then only export to Shapefiles
> if you need to deliver your data to your client. Shapefiles are from the
> past century and should be avoided - for many reasons.
> I also remember that Marco Hugentobler (Sourcepole) was contracted to
> fix these Shapefile issues for the province of Vorarlberg - though I may
> be wrong. So there is already someone investing to fix this bug. Marco -
> correct me if I am wrong.
> Hopefully, there can be a fix about this Shapefile issue in QGIS 2.14
> Andreas
> On 2016-01-20 07:34, Matthias Kuhn wrote:
> > Hi all,
> > Here is some more eplanation of the issue:
> > http://gis.stackexchange.com/questions/58101/how-to-avoid-creating-corrup
> > t-shapefiles-during-editing/79677#79677
> > I spent quite some time to fix this issue as much as possible from QGIS
> > side (Hint: "they" are not just lazy and ignore problems ;-) ) It seems
> > that there is also a second (closely related) problem left to be solved
> > and it looks that it can be solved by shipping a newer GDAL version.
> > Apparently the issue has not been completely solved yet and apparently
> > it is considered to be from "critical" over "big fail" to "fatal" from
> > the audience. It would be awesome if you could ask the maintainer of
> > your operation system's builds for a quote to ship QGIS with GDAL 2.0 on
> > your operation system. We will gladly provide you with email addresses.
> > Best regards,
> > Matthias
> > On 01/19/2016 10:54 PM, Mats Elfström wrote:
> > Hi!
> > While all that Nicolas and Uwe says is generally true and reasonable, it
> > is also true that bugs and errors can be more or less dangerous. With
> > limited resources, it is even more important that bugs are handled
> > according to a simple risk analysis. In this case, it would go something
> > like this:
> > What is the probability that users will edit shape files (high, moderate,
> > low): High What is the probability that QGIS will damage shape files:
> > Moderate (as I understand) What is the severity of the potential damage
> > (fatal, reparable, negligible): Fatal And High * Moderate * Fatal equals
> > a probable risk for fatal damage, which ought to prompt for a rapid fix
> > of ths bug, regardless of where it resides in the QGIS ecosystem. But
> > oddly enough, I have browsed through many of the posts on the shape file
> > issue, but have yet to find a technical description of the exact cause
> > and origin of this bug.
> > Regards, Mats.E
> > 2016-01-19 22:14 GMT+01:00 Saber Razmjooei
> > <saber.razmjooei at lutraconsulting.co.uk>:
> > Dear Uwe,
> > There are some work-arounds and solutions provided within the ticket.
> > Also, work is underway to resolve the issue in the next LTR release. Last
> > time I checked (5 minutes ago) it is still present in master.
> > I totally agree with you that there should be a warning to users to make
> > them aware of this limitation.
> > In general, QGIS and other GIS/non-GIS proprietary software come with
> > bugs. The reason developers haven't fixed this bug and other bugs is due
> > to lack of resources (time, money).
> > The project steering committee is committed to resolving the bugs and
> > they have already allocated a big proportion of their income for bug
> > fixing. You can see last year's financial report hear:
> > http://qgis.org/en/_downloads/PublicQGISfinancialreport2014.pdf
> > If you think, there should be more work done to increase the quality of
> > QGIS, you can get involved or contribute to the project:
> > http://qgis.org/en/site/getinvolved/governance/sponsorship/sponsorship.ht
> > ml
> > Regards,
> > Saber
> > FROM: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] ON BEHALF OF
> > Uwe Fischer SENT: 19 January 2016 19:10
> > TO: 'qgis-user ML'
> > SUBJECT: [Qgis-user] QGIS big fail in deleting Shapes!!
> > Hello all,
> > today I was working on a shape dataset and I had to delete some features.
> > Later I opened the shapefile in ArcMap by chance and I found that the
> > features were not deleted. They still did exist. I repeated the process
> > - and got the same result. Then, searching the internet, I found this
> > incredible post: https://hub.qgis.org/issues/11007
> > It is a well known problem (for 1,5 years!!) that _QGIS is not able to
> > delete shapes in a reliable way_!! I was horrified to read this because
> > it is the same as if a Word processor would not be able to delete a
> > letter from a text. I cannot understand why the QGIS developers haven't
> > fix that yet. If QGIS really wants to compete with ArcMap, they should
> > fix it as soon as possible. At least, the according menu entries or
> > buttons should be inactivated if they don't bring out reliable results.
> > My questions are:
> > · is this information still up to date? I can't read all of the
> > 80 answers to the post now to get in-depth information ...
> > · does anybody have information about how they are planning to
> > handle this problem at the development team?
> > · is there a workaround for this? Do the GRASS vector tools bring
> > out reliable results?
> > · are there more of those software errors in QGIS that might lead
> > to huge problems in working on vector data and sharing them with others?
> > If so, is there a „black list" of things one is never allowed to use in
> > QGIS if you don't want to destroy your datasets?
> > Regards,
> > Uwe Fischer
> > This email and any files transmitted with it are confidential and
> > intended solely for the use of the individual or entity to whom they are
> > addressed. If you have received this email in error please notify the
> > system manager. This message contains confidential information and is
> > intended only for the individual named. If you are not the named
> > addressee you should not disseminate, distribute or copy this e-mail.
> > Please notify the sender immediately by e-mail if you have received this
> > e-mail by mistake and delete this e-mail from your system. If you are
> > not the intended recipient you are notified that disclosing, copying,
> > distributing or taking any action in reliance on the contents of this
> > information is strictly prohibited.
> > Whilst reasonable care has been taken to avoid virus transmission, no
> > responsibility for viruses is taken and it is your responsibility to
> > carry out such checks as you feel appropriate.
> > If this email contains a quote or offer to sell products, carry out work
> > or perform services then our standard terms and conditions [1] shall
> > apply unless explicitly stated otherwise.
> > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
http://www.spatialys.com
